Hi Loren,
If I understand you correctly from the archives, to change out the brake shaft seal on the big 400 into the 30 series. I want to leave the diff carrier/brake pad plate fastened and go inbetween it & the shaft to remove old seal and cover splines to install new one the same way correct? I have the parts breakdown but hadn't read the service manual yet. For all the Cases we have this is the first one I've had to do Thanks
Brad
Brad
