Paul Henry
This may be a little long winded, but...
I have an 800 COM gas. If I start the tractor after it has sat for a day and put a disk/4rw planter in the ground, it will raise the implement after the first round. However, after that when the tractor is running warm, the hydraulics (even after throttling all the way up) will not lift. I have made do.
Last winter I never was able to use the tractor/snowblower because something was frozen. I chalked it up to water in the hyd fluid that was crystallizing OR freezing in the Eagle Hitch lift cylinder. So last spring I changed the fluid. The hydraulics still wouldn"t lift any implement, but again I made do.
This winter, as long as the temp was above 30ish, everything seemed to be okay. But rarely do I need to blow snow then! There were times that the spout wouldn"t even turn, much less the hitch lift the blower.
So... I am thinking one of two things. 1) Worn out pump. 2) Filter
I am in NE SD and still have considerable snow on the ground so I have not had the chance to even look at the back end. Over the winter, though I bought a pump (the whole assembly). What to do next?
If I replace the pump, do I just pull the whole assembly off and put the new one on? (I don"t know much about hyd pumps) If so, can I find a gasket or will the "liquid gasket" be sufficient?
If it is the filter, is it something that is cleaned or is it paper? Can I find replacement ones?
I know this is long, but I am in search of help. I follow this thread and look to you experts to assist me. I am hoping to pick up a yellow 1070 later this month, and will probably have many more questions.
Thank you in advance!
Paul
Paul
