I have a 1370 I just brought in and got running. Engine seems good, powershift, tranny and lift all work fine. Problem is when you push the clutch in you have to set your toe back under it and ease it up to take off. Tractor sat 4 years, man assures me it did not do that before. What is the problem?
the pivot on the clutch pedal it's self could be holding it down I have seen that before, I have used PB Blaster to free it up then lube the pivot with some oil, also have seen the pivot outside by the RPS valve do the same thing cnt
My 1370 did the same thing after sitting, spring was broken on clutch pedal under dash and a little liquid wrench on all linkages and its like new. Good luck
Ben
they are not as bad as they look,,well if you can stand on your head inside the cab LOL I have a rolling stair way that I rool up tothe door and lay a piece of plywood down from it to the door on the cab entry point and that helps but you still have a kink in your back for a bit
