Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Brass Lined C-4 Clutch Disc
brokengun
03-23-2013 15:22:55
The sintered plates were bullet proof.
When i had a failure on the C4 clutch i wanted to put those in my 1370 but couldnt find any new ones so I went with the paper fider stuff from case/ih.
I did however find sintered brake disks and sintered plates for the differential.
I was told that when case originally made the 70 series they came out with the sintered plates even for the PTO.
The things wouldnt hardly wear and you could use any oil against them. They could even take water!
For some reason case changed to the paper fiber plate and had what can only be described as a glue problem.
i wish someone would make the sintered plates again.
Jeff B.
03-24-2013 21:06:25
 Re: Brass Lined C-4 Clutch Disc in reply to brokengun, 03-23-2013 15:22:55
Check with a company called Alto Products out of Atmore, Alabama. They are the largest aftermarket plate supplier in the U.S. (maybe the world) for transmission stuff. they make plates for motorcycle, marine, industrial, and some tractors. Most of their stuff is various kinds of paper, but I believe they do some of the metallic ones also. I've seen smaller ones like that before, I think it was a marine application, and also a small ford tractor pto drive. The paper stuff won't hold up to anything where water could be present. The heat will steam the lining right off in big hunks. Send me an e-mail and I'll give you my 800 number. I'd be glad to call them and find out if they have what you need. We buy thousands of plates from them, so I like to think I'm on their good side, lol.
1370rod
03-24-2013 05:19:06
I should have mentioned the number below is for the good plates they used in the 30 series and very early 70's. It still is available, always has been just cost more than those cheap paper ones they began using in new production.
1370rod
03-23-2013 15:49:50
For the PTO plates use A33012, I aways thought those paper ones were junk.
brokengun
03-24-2013 11:53:58
 Re: Brass Lined C-4 Clutch Disc in reply to 1370rod, 03-23-2013 15:49:50
1370Rod can you still get the sintered C4 plates?
1370rod
03-24-2013 12:36:51
 Re: Brass Lined C-4 Clutch Disc in reply to brokengun, 03-24-2013 11:53:58
No, The No. above is for the sintered (brass) style PTO plates I thought you were referring to. But from now on when I see the C4 in the salvage yard I'm going to make sure I buy them. Rod.
