TractorLinks.com
Show Parts for Model:
Re: Case 885 3 point and pto none working
RGMartin
03-22-2013 14:01:03
The shaft looks usable, but has a lot more wear on the splines than I would have expected. The front end is supposed to look like that, that is where it goes into the pilot bearing in the end of the crankshaft.
A&I(Deere) offers the clutch parts reasonably, I have had good luck with them. Sparex does too.
Next step is to split it and see exactly what is wrong in the clutch pack. It is pretty straight forward to split. Best case, and it is just the front clutch disc has sheared its rivets or splines. Aftermarket discs are about $100. I'd probably do the back disc(if showing wear, another $100) and throwout bearing($60) if I were doing it for myself.
StephsOliver
03-22-2013 18:59:20
 Re: Case 885 3 point and pto none working in reply to RGMartin, 03-22-2013 14:01:03
I called local dealer and he can get the PTO friction plate for $154 and Tractor clutch for $183. I will split tractor tomorrow, I have fuel tank and every thing else removed and set aside. I need to remove the power steering lines Then unbolt and roll apart. I have the back have blocked up and will use a engine hoist to move the front half away. This is actually still a simple tractor to work on. I ordered the manual for it but i might have it back together before it arrives.
I want to thank you all for the help and advice. And will keep you updated to what i find when i split the case.
RGMartin
03-22-2013 19:16:49
 Re: Case 885 3 point and pto none working in reply to StephsOliver, 03-22-2013 18:59:20
SSSSHHH... Don't tell anyone or you will drive their prices up.
Seems pretty steep on the parts prices. A&I is showing them in stock at $99 and $105, $59 for the bearing.
StephsOliver
03-22-2013 20:23:47
 Re: Case 885 3 point and pto none working in reply to RGMartin, 03-22-2013 19:16:49
thank you i went to their site and they have a wharehouse right here local. I will check them out Monday.
Thank you again.
