TractorLinks.com
Show Parts for Model:
Re: STARTING FLUID, The Do's and Don'ts !
John Saeli
03-20-2013 05:28:52
When any CASE engine will not start below 60 degrees, without ether, something is wrong. No cracks? Try this & get back, if you would. Fill the radiator right to the top, over the vent & look for bubbles. She'll push some out as she warms, but shouldn't see compression bubbles. Let us know.
casecollectorsc
03-20-2013 07:18:22
 Re: STARTING FLUID, The Do's and Don'ts ! in reply to John Saeli, 03-20-2013 05:28:52
For sure there's no bubbles from any of the Case diesels on this farm. I had a 830 irrigation engine that lost a hose and before the Murphy switch could shut it down a head cracked but thats it. The 1030 came here in 72 with a new block and new overhaul. Case apparently had line bore problems with some early 451 blocks and Case replaced them. This tractor was one of them. New engine. Cold as heck day just before freeze up in the fall when it was delivered. Wouldn't start off the truck. Pre heat, still no go. Waited a while, then a whiff of ether and it was running. The old wore out 500 is the best cold starter we've got followed by the 4 930 westerns.
John Saeli
03-20-2013 08:01:38
 Re: STARTING FLUID, The Do's and Don'ts ! in reply to casecollectorsc, 03-20-2013 07:18:22
You won't know until you fill right up in the neck. Keep us posted.
