830 wheatland and row crop
Does anyone know if the 830 low tin wheatlands and the 830 low tin row crops used the same bull gears?
I am wanting to put row crop axles on the wheatland and wanting to know if I can just change the axle housings and use the wheatland bull gears.
I changed a big 400 the same way. The difference is in the ring gear and pinion. The bull gear is the same. The ring gear and pinion is one tooth difference.
