If the batteries are up and the starter spins good, then use the preheater for 30 seconds before trying to start. I'll get shot for this, but if you know what you're doing, give it a small shot of ether in the air cleaner.
Don't use ether if you've used the preheat. It will ignite in the intake manifold which is a bad thing.
Harry
I know everyone has their own ideas about ether the less you use is better. Get to know your equipment if you need it maybe 1sec is enough maybe more etc. I drove a Freightliner with a Mercedes Engine, very few times it needed ether bit when it did needed a lot. Case engines seem to just need a whiff. I NEVER use ether until I see the white smoke.
