TractorLinks.com
Show Parts for Model:
Re: ether spray
1370rod
03-17-2013 19:26:41
If you have to use a cold starting aid such as starting fluid,I believe it should ALWAYS be applied before the air filters. The best being at the air intake. Now I am not promoting the use of the product, merely answering the question. In a perfect world we would not use it, but unfortunetly we know there are times and places nothing else will do. In some cases(pardon the pun) its not the product causing the damage , its the nut holding the can. Always apply product before filters, the engine MUST be cranking at NORMAL cranking SPEED, and use ONLY enough to start engine. If engine starts immediately you used to much. If engine is not cranking at normal speed, do not apply. If you can not have engine cranking durring application do not use product. Have an engine heater is by far the best solution to start a cold engine. But if a situation arises and there is no other choice to get an cold engine started. By appling a starting aid PROPERLY can save the day. However as stated before avoiding its use will save you from missusing it. Rod.
McKerrow630
03-18-2013 06:01:11
 Re: ether spray in reply to 1370rod, 03-17-2013 19:26:41
Rod, sure wish you woulda been around in 1960's cause I beleive the 700 life woulda been spared afew more yrs. I remember when dad would "pump drugs" into the ole girl while i turned the key!!! 20 below and 30wt. oil........But thats what the case dealer told dad to do. Boy would nasty sound!!! but I was only 11 or 12 yrs. old. Thanks for sharing
John Saeli
03-18-2013 05:03:01
Rod: Always value your posts, but I never use ether to start any of my CASE engines. We do have a 6V-53 screamer that needs a snort once in a while, but never on the CASE engines. I'm a stickler on good batteries & cables. When I do a valve job on a CASE head, the valves & seats never get ground, always replaced. Grind valves & seats & you guaranteed a hard starting diesel.
1370rod
03-18-2013 05:28:46
 Re: ether spray in reply to John Saeli, 03-18-2013 05:03:01
I definetly agree new valves and seats always helps the cold start problems, Rod.
