TractorLinks.com
Show Parts for Model:
Re: Plowing question for you guys, hope someone knows
jon f mn
02-26-2013 19:33:25
It will be tight in the furrow, but a 5-20's should work for on land too. It's 4" wider than 6-16's and they pull them onland a lot.
G1355
02-26-2013 19:41:48
 Re: Plowing question for you guys, hope someone knows in reply to jon f mn, 02-26-2013 19:33:25
So it's not an onland so do you think it will work?
jon f mn
02-26-2013 20:31:57
 Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-26-2013 19:41:48
There is probly enough adjustment to make it onland. Post a pic. We even used our 5-16's onland if we had to do any spring plowing. It pulled a bit to the side but worked, and we could run with both duals on.
G1355
02-27-2013 05:25:36
 Re: Plowing question for you guys, hope someone knows in reply to jon f mn, 02-26-2013 20:31:57
Right here's one just like it, I posted it on the bottom of the page to
jon f mn
02-27-2013 05:48:22
 Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-27-2013 05:25:36
I saw that after. lol Those will adjust far enough over to plow on land. You will have to drive right next to the furrow but it will work. With 20's it should work pretty good, as I said it's wider than a 6-16's and they do those onland a lot.
casecollectorsc
02-27-2013 05:57:32
 Re: Plowing question for you guys, hope someone knows in reply to jon f mn, 02-27-2013 05:48:22
If you move the hitch over on that plow so it can be pulled on land it won't pull straight. That plow wasn't made to be pulled onland. Just try it in furrow, you aren't out anything. It either works or it doesn't.
