TractorLinks.com
Show Parts for Model:
Re: Plowing question for you guys, hope someone knows
G1355
02-26-2013 19:26:50
The plow we have is 5-20s if that helps, if you know if the tire fits in the furrow that will be great
Adirondack case guy
02-26-2013 19:54:42
 Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-26-2013 19:26:50
The tire will leave markes on the previous pass. If you sock the plow in 10-12" you may be able to cover the track. Not really a good setup for infurrow plowing. An onland 3pt, 6 plus bottom would be much better suited.
Loren
G1355
02-26-2013 19:59:52
 Re: Plowing question for you guys, hope someone knows in reply to Adirondack case guy, 02-26-2013 19:54:42
So a plow like this one wont work very well, or not at all
Adirondack case guy
02-26-2013 20:19:10
 Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-26-2013 19:59:52
I didn't say it wouldn't work. Your tires are plenty fat for a furrow. You have ample power to burry the plow and throw a lot of dirt to cover the tire imprint in the plowed ground. Hook her up and go plow, and see what happens. If you like the results thums up! If you don't move on to an on land plow.
Loren
G1355
02-27-2013 05:24:26
 Re: Plowing question for you guys, hope someone knows in reply to Adirondack case guy, 02-26-2013 20:19:10
Alright thanks, hope to plow a little pasture up this spring with the old girl if we get her up and running.
Jeff From WI.
02-27-2013 06:31:01
 Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-27-2013 05:24:26
We sure would be happy to give her a test run around here on more then a few acres too if you would. Hope to see some pics of the old girl plowing.
Jeff
G1355
02-27-2013 09:46:52
 Re: Plowing question for you guys, hope someone knows in reply to Jeff From WI., 02-27-2013 06:31:01
Alright I'll take pictures this spring if it works
