Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Plowing question for you guys, hope someone knows
[Return to Forum]
G1355
02-26-2013 19:15:20
67.224.60.152
So I posted that picture of the 1470tk me and my brother bought, it has 28.1-26 tires and wondered if you can plow with a 3 point plow, a 720 international is what we have dont know if the tire would fit in the furrow or not. or if you need a on land plow, hope it works with the three point, otherwise were gonna have to find a on land plow. Thanks
[Reply]   [No Email]
ihcowner
02-27-2013 09:47:24
99.196.174.238
Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-26-2013 19:15:20
We pulled a 710 IH 6-16 plow for years with a 2470 with 23.1 x30 rice tires running in the furrow.
  [Reply]  [No Email]
David Lohf
02-27-2013 07:22:45
66.43.213.205
I would not do it unless you have onland hitch. What you will do is wreck the inner sidewall of your tire,and they don't give them away for sure. Plus it's very hard on steering cylinders,and pivots.
  [Reply]  [No Email]
Paul A Young
02-27-2013 06:04:39
74.206.50.250
We used 23.1X30 on our 2470 for years pulling a 6-18 plow.The tires were really too wide but we got along fine.Your setup will be the same,not perfect but work just fine.
  [Reply]  [No Email]
jon f mn
02-26-2013 19:33:25
70.195.65.155
It will be tight in the furrow, but a 5-20's should work for on land too. It's 4" wider than 6-16's and they pull them onland a lot.
  [Reply]  [No Email]
G1355
02-26-2013 19:41:48
67.224.60.152
Re: Plowing question for you guys, hope someone knows in reply to jon f mn, 02-26-2013 19:33:25
So it's not an onland so do you think it will work?
  [Reply]  [No Email]
jon f mn
02-26-2013 20:31:57
70.195.65.155
Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-26-2013 19:41:48
There is probly enough adjustment to make it onland. Post a pic. We even used our 5-16's onland if we had to do any spring plowing. It pulled a bit to the side but worked, and we could run with both duals on.
  [Reply]  [No Email]
G1355
02-27-2013 05:25:36
67.224.60.152
Re: Plowing question for you guys, hope someone knows in reply to jon f mn, 02-26-2013 20:31:57
Right here's one just like it, I posted it on the bottom of the page to
  [Reply]  [No Email]
jon f mn
02-27-2013 05:48:22
70.195.65.155
Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-27-2013 05:25:36
I saw that after. lol Those will adjust far enough over to plow on land. You will have to drive right next to the furrow but it will work. With 20's it should work pretty good, as I said it's wider than a 6-16's and they do those onland a lot.
  [Reply]  [No Email]
casecollectorsc
02-27-2013 05:57:32
75.102.167.162
Re: Plowing question for you guys, hope someone knows in reply to jon f mn, 02-27-2013 05:48:22
If you move the hitch over on that plow so it can be pulled on land it won't pull straight. That plow wasn't made to be pulled onland. Just try it in furrow, you aren't out anything. It either works or it doesn't.
  [Reply]  [No Email]
G1355
02-26-2013 19:26:50
67.224.60.152
The plow we have is 5-20s if that helps, if you know if the tire fits in the furrow that will be great
  [Reply]  [No Email]
Adirondack case guy
02-26-2013 19:54:42
74.69.160.79
Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-26-2013 19:26:50
The tire will leave markes on the previous pass. If you sock the plow in 10-12" you may be able to cover the track. Not really a good setup for infurrow plowing. An onland 3pt, 6 plus bottom would be much better suited.
Loren
  [Reply]  [No Email]
G1355
02-26-2013 19:59:52
67.224.60.152
Re: Plowing question for you guys, hope someone knows in reply to Adirondack case guy, 02-26-2013 19:54:42
So a plow like this one wont work very well, or not at all
  [Reply]  [No Email]
Adirondack case guy
02-26-2013 20:19:10
74.69.160.79
Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-26-2013 19:59:52
I didn't say it wouldn't work. Your tires are plenty fat for a furrow. You have ample power to burry the plow and throw a lot of dirt to cover the tire imprint in the plowed ground. Hook her up and go plow, and see what happens. If you like the results thums up! If you don't move on to an on land plow.
Loren
  [Reply]  [No Email]
G1355
02-27-2013 05:24:26
67.224.60.152
Re: Plowing question for you guys, hope someone knows in reply to Adirondack case guy, 02-26-2013 20:19:10
Alright thanks, hope to plow a little pasture up this spring with the old girl if we get her up and running.
  [Reply]  [No Email]
Jeff From WI.
02-27-2013 06:31:01
50.105.214.113
Re: Plowing question for you guys, hope someone knows in reply to G1355, 02-27-2013 05:24:26
We sure would be happy to give her a test run around here on more then a few acres too if you would. Hope to see some pics of the old girl plowing.
Jeff
  [Reply]  [No Email]
G1355
02-27-2013 09:46:52
66.43.240.157
Re: Plowing question for you guys, hope someone knows in reply to Jeff From WI., 02-27-2013 06:31:01
Alright I'll take pictures this spring if it works
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
