retired farmer
You being an old Case man, figured you might have an idea on this. We have a Case 2290 that leaks oil from the end cap on the starter. Started doing it several years ago. Two different mechanics have had it apart several times and have replaced the seals in it. Put it back on and within two or three hours of running, oil starts coming out of the end cap. Have checked the transmission breather and it is not plugged. Must be a pressure build up somewhere around the flywheel, but we can't figure where and why it would push oil thru the starter case and out the end. Ever had that happen on any of your tractors? Thanks.
