Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Case 730 Year Productiion
[Return to Forum]
Catskill Case
02-24-2013 08:55:50
68.70.31.209
New to Forum. I just bought a Case 741, Dual Range and would like to identify the year that it was produced- Serial number is- 8232441.
Can anyone tell the year it was made? or where I should look to find out?
[Reply]   [No Email]
Catskill Case
03-28-2013 02:36:54
68.70.31.209
 Re: Case 730 Year Productiion in reply to Catskill Case, 02-24-2013 08:55:50
A quick update on this 730....fixed hydraulic lift- spool sticking in pump- have 1500 psi pressure; replaced top and bottom steering bushings; straightened steering linkage and replaced tie-rods; replaced fluids- tans/hydraulic and engine- cleaned hydraulic screen/filter; rough cleaning; fixed drawbar connection. Hope to paint it and the 300 when weather warms up a little more.
[Reply]  [No Email]
Catskill Case
03-29-2013 11:08:12
68.70.31.209
 Re: Case 730 Year Productiion in reply to Catskill Case, 03-28-2013 02:36:54
Hopefully pics make it this time.
[Reply]  [No Email]
Catskill Case
03-28-2013 02:46:08
68.70.31.209
Photo of 730 after updates.
[Reply]  [No Email]
Catskill Case
03-28-2013 03:02:55
68.70.31.209
 Re: Case 730 Year Productiion in reply to Catskill Case, 03-28-2013 02:46:08
Trying photo upload again. Not working for me. will try later.
[Reply]  [No Email]
Catskill Case
02-24-2013 10:43:33
68.70.31.209
Here's first attempt to upload photo
[Reply]  [No Email]
dbock
02-24-2013 10:53:25
76.2.169.54
 Re: Case 730 Year Productiion in reply to Catskill Case, 02-24-2013 10:43:33
Do you have a picture of the back end of the tractor? Could they have hooked the hoses up wrong when they reinstalled the hitch?
[Reply]  [No Email]
Catskill Case
02-24-2013 11:27:41
68.70.31.209
 Re: Case 730 Year Productiion in reply to dbock, 02-24-2013 10:53:25
Took 3 pics of rear end...doesn't look like any hoses had been disconnected/reconnected when I looked at it and took these pics. I purchased from a dealer after last owner traded in. Last owner dropped off eagle hitch draft arms and dealer reinstalled them. I don't remember dealer saying he had to reconnect hydraulics. But he did pull the fill cap/dipstick and we saw moisture/water had gotten in reservoir.
[Reply]  [No Email]
dbock
02-24-2013 18:03:46
76.2.169.54
 Re: Case 730 Year Productiion in reply to Catskill Case, 02-24-2013 11:27:41
That looks right. Does the other remote work?
[Reply]  [No Email]
Adirondack case guy
02-24-2013 09:33:43
74.69.160.79
It would be a mid year 1964. That would make it a "high tin" eagle hitch tractor. I presume that there was not a C after 741 so it is a standard clutch gasser. The C denotes Case-O-Matic tranny.
Does your handle reflect that you live in NY., and if so where if you don't mind answering.
Loren
[Reply]  [No Email]
Catskill Case
02-24-2013 10:21:25
68.70.31.209
 Re: Case 730 Year Productiion in reply to Adirondack case guy, 02-24-2013 09:33:43
Thanks for the Info Adirondack. I've been looking for a 50-60 hp tractor for awhile to go with a 300 bulldog nose that I already own.
Yes, I do live in NY- Deposit, which is in Delaware County. I assume your up in the north country??
[Reply]  [No Email]
Adirondack case guy
02-24-2013 13:11:39
74.69.160.79
 Re: Case 730 Year Productiion in reply to Catskill Case, 02-24-2013 10:21:25
You should hear a hyd squeel when you move the remote lever and see the hoses jump when you move that lever. Also, how does the lever feel that operates the 3pt.? Does it come back to center when pulled back, and move forward and lock for float? It is posible that the finger is broke off in the control valve for the 3pt. It is detented and you should be able to feel the spool move through the detents as you move it up and down. The guys here will walk you any issues you have, after you are able to try it out.
Loren
[Reply]  [No Email]
Catskill Case
02-25-2013 16:51:11
68.70.31.209
 Re: Case 730 Year Productiion in reply to Adirondack case guy, 02-24-2013 13:11:39
Thanks for the interest. I think I"ll be able to have it trucked home later this week and then start on it.
[Reply]  [No Email]
Adirondack case guy
02-24-2013 12:48:48
74.69.160.79
The very northern tip of Otsego Co. We were Case dealers since 1931-1986.
Loren
[Reply]  [No Email]
jon f mn
02-24-2013 09:23:32
70.194.74.14
Click on the serial numbers on the left and just look it up, it's easy. And post a pic, we all like to see what ya got. Welcome to the site.
[Reply]  [No Email]
Catskill Case
02-24-2013 09:11:08
68.70.31.209
I plan on doing a modest restoration on this 741.
Tin is good, engine tight (no smoke), all or most decals and emblems are still on it. Clutch and brakes seem fine, however, I wasn't able to run it with a load on motor. I bought and paid for it yesterday and will have it hauled home within the next two weeks. Once here I will be able to go through it more thoroughly to see what needs to be addressed.
One thing I do know is the 3-point hitch arms do not raise. Last owner used this to pull a drawbar towed 8' brush hog and removed 3-pt hitch 5 years ago. He put them back on to sell and hydraulics don't lift. I pulled the Trans/hydraulic dip stick and see that there is some water build-up; so drain, check screen/filter and refill will be tried first. Thanks for any advice or input.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
