case 530ck pushes out coolant
plywood
New User
I've got 188 diesel in a case 530ck that started pushing coolant out of the overflow tube. I replaced the thermostat and installed a new water pump but that did not help. I am not getting any water in my engine oil and the motor runs very smooth. I have noticed a small amount of air bubbles constantly coming to the top of the radiator. Where these bubbles are coming from has got me stumped. Has anyone ran accross this problem before that could maybe help me isolate the problem? Thanks Plywood
Its more than likely the head gasket leaking a little. Could be the head but that has to come off anyway regardless of which spot is the problem then you will know for sure. Rod.
try retorguing the head,search archives for more info , ya never know it may have never been done rite ,,, if it were mine ,after retorqing.. i would try either bars leak , or d ik e in the radiator,,
Thanks Rod I'm going to retighten the head first and if that don't do it then off comes the head.
Thanks again,Plywood
If you don't have any luck with those suggestions which I am afraid will happen, remove the head and check the sleeve protrusion at the block, they should be even all around the sleeve and .002--.004 above the block. The sleeve should be clamped down hard when making this measurement.
Back in the day we had many that the sleeves would settle and the gasket lose it's ability to seal. The 530 had "narrow flange sleeves" and later 188s were built with "wide flange sleeves" with more counterbore support. It was common practice to plane the block surface a few thou. and enlarge the counterbores and remachine the counterbore to set the newer sleeve to the right height. The later wide counterbore sleeves were then installed.
This must be done by a competent machine shop and only the bare minimum material removed as piston to head and valve clearance can be an issue if care is not taken to check clearances.
Only the bare minimum can be taken off the block surface, enough to get a clean counterbore where the sleeve sets.
Also on the first 188s we experienced sleeve breakage about 1/4-5/16 down, a radial crack in the area where there is no stud. Sometimes the only way to find them was to dry everything up and look for a seep line on the interior of the sleeve.
Great engines however after the changes to the blocks and sleeves were made problems dropped dramatically and they will be remembered as one of the best engines ever made.
mEl
Mel,
Does anyone offer the multi thickness fire rings yet? We had the the sleeve clamping tool that sat over the sleeve, to measure flange protrusion, and after measuring that, we selected the proper thickness fire rings for the head gasket. Just wondering about that. We had one of the first 630s produced, up on the farm and it was a real arz ache.
Loren
If the head wasn't retorqued directly after initial install and the engine is houred up and then started blowing off into radiator, IT IS TOO LATE to retorque, and bars leak won't stop a compression leak in a head gasket.
Loren
Doom and gloom me , says it has a cracked block on the top deck, between the sleeves. Most do here at my place. Lower counterbores are a problem also.
Don L.
ACG,
I totally agree, with the narrow flange sleeves there were no procedures or dump in solutions that would solve the problem caused by a weak head gasket seal on a 400 PSI cranking compression engine. There is just no substitute for having the engine in tip top shape mechanically. Sorry to hear about the cracked block and the lower bore problems. A plus, any Case engine through the 207 diesel is a fit.
mEl
