| Case Tractors Discussion Forum |
Topic: VAI problems - need some help
[Return to Forum]
| Author |
[Modern View]
| Fry
02-22-2013 17:47:10
207.118.141.220
I've been having problems with my VAI this winter that have been getting progressively worse. It's mainly a power issue - it runs like a top at idle or when I give it gas, but as soon as I start pushing snow or going uphill, even at full throttle, it starts chugging.Then this evening things got worse. I could run it for about 10 minutes and then as soon as I tried to move at all, I lost power to the point of snubbing it. It even died while just sitting at idle once. I would let it sit for about 10 minutes and start it and go through the cycle all over again. I know I have plenty of gas in the tank and good flow to the carb. I think I have carb issues - I can't seem to get any results from adjusting the power screw. I think I'm missing on #3 cylinder - I'm putting in new plugs tomorrow. Then I noticed, and I could've been imagining it because the snow was flying, that every time I started it, I thought I could see the faintest spark on the bracket that holds what I think is the coil (black cylinder wired between the alternator and distributor). Any insight or ideas anyone can provide would be greatly appreciated. |
| Bret4207
02-23-2013 04:51:26
64.19.90.196
Re: VAI problems - need some help in reply to Fry, 02-22-2013 17:47:10
| Start with the simple stuff- if you're seeing sparks check all the wiring insulation. Wire is pretty cheap compared to buying a carb. Check the gov. Check the distributor, it may have moved out of proper time. Check points for proper gap and condition. Check cap, rotor and plug wires for deterioration, cracks, etc. Check and service the plugs. Wouldn't hurt to do a compression test as long as the plugs are out. Make sure the air cleaner isn't full of ice! Happens every winter a couple of my tractors.
When you undo the gas line to carb you should get a real free flow. If you do, then a carb rebuild by a qualified person might help. Have you drained the carb? Water can build up and freeze in the bottom of the bowl and not let the float drop enough to supply enough gas.
Start at square one. |
| Ande
02-22-2013 20:00:04
216.196.94.16
| Air cleaner open? Oil free from ice? |
| old
02-22-2013 18:23:13
209.86.226.57
| First off check that the gov is doing its job by running it at idle and grab the gov to carb rod and try to speed up the RPM. It should fight you if it does not then it is a gov problem. If it does fight you check you spark and make sure it is a good blue/white and will jump a 1/4 inch gap or more. If you have that then pull the carb drain plug and make sure you have a good steady flow of gas from there. Catch the gas to look for water etc. Next when was the last time you serviced the air cleaner it could be full of water and dirt |
| Dale from NW WA
02-22-2013 19:51:17
67.206.185.50
Re: VAI problems - need some help in reply to old, 02-22-2013 18:23:13
| After your last part about a faint spark from coil I am thinking change coil. But there again I am thinking again, and that gets me in trouble Dale |
| old
02-22-2013 20:39:11
209.86.226.27
Re: VAI problems - need some help in reply to Dale from NW WA, 02-22-2013 19:51:17
| Most believed to be coil problems are in fact points or condenser problems and a coil is the least likely to go bad |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
