TractorLinks.com
Show Parts for Model:
Re: Propane LA
Tommy Railsback
02-22-2013 16:07:02
That would be an addon; propane equipment came out in 1948 or 1949.
farmer-chad
02-22-2013 17:09:07
 Re: Propane LA in reply to Tommy Railsback, 02-22-2013 16:07:02
Thanks for the reply, my next question would be was the propane conversion a Case/ dealer add-on, or just a homemade farmer thing.
Thanks.
Don Rudolph
02-22-2013 17:17:51
 Re: Propane LA in reply to farmer-chad, 02-22-2013 17:09:07
Case offered a kit to retrofit tractors with LP that included everything you needed, along with a new head, if you wanted the same HP as with gas. Kits were also offered by aftermarket companies. It sounds like the one you are looking at is aftermarket. Don
Jimmie D. Phelps
02-22-2013 17:35:55
 Re: Propane LA in reply to Don Rudolph, 02-22-2013 17:17:51
I put my 48 LA on propane in 1957 an bought the kit. I posted this before but here it is. I bought the kit which had, new head,tank, reg, carb, I also put in new Sleeves and pistons. Painted it all for $404.00.. The 48 LA had more power than the ones through 47. and when I went LP it uped my power and did not use more fuel per hr. than on gas. I pulled a 15ft oneway the first time over and a 15 an 12 ft togather the second time over. and than two 12ft. rod weeders. or a 16ft JDCC Cuilt. with 16 ft of rod behind.
Don Rudolph
02-22-2013 18:17:08
 Re: Propane LA in reply to Jimmie D. Phelps, 02-22-2013 17:35:55
Jimmy,
Did a new hood come with that kit, or did you have to modify the one you had? Don
Jimmie D. Phelps
02-23-2013 08:44:28
 Re: Propane LA in reply to Don Rudolph, 02-22-2013 18:17:08
I had to saw off the hood. the flare on each side came with the kit.
