| Case Tractors Discussion Forum |
Topic: o-ring renewal
[Return to Forum]
| Author |
[Modern View]
| case trader
02-22-2013 08:40:15
67.142.162.22
anybody have any tricks getting O-rings to soften or swell to reseal (have a piece in brake fluid 1 in penetrating oil 1 in brake cleaner just testing, will try Viagra later) |
[Reply] [No Email] | |
| case trader
02-22-2013 12:07:16
67.142.162.25
Re: o-ring renewal in reply to case trader, 02-22-2013 08:40:15
| wow didn't expect this much response,what i'm referring to is the shifter shafts on the 90 series I was looking for something to put on the shaft and work in to o-ring from outside so as not to contaminate trans.no big leak just messy if you park inside.and takes all morning to fix right.the one I realy enjoy is between the eng. and trans housing on the 96 series that takes all afternoon and the o-ring cost 1.49 from case |
| pete 23
02-22-2013 11:12:22
74.47.40.242
| I'm wondering if he isn't trying to avoid splitting a tractor to replace the $2 o-ring. If the o-ring is made to not swell in hy-tran, I doubt if you will be successful unless it swells all other o-rings it comes in contact with as well which would not be good if it is indeed an o-ring in a transmission. Kind of guessing on his intent here from reading another post. |
| 1031D
02-22-2013 10:10:26
107.8.250.69
| I think he is trying to cheat at a leaky liner o-ring. Best bet there is to pull the liners, new o-rings, and clean all the junk out of the block. |
| Case Nutty 1660
02-22-2013 10:29:58
75.127.24.27
Re: o-ring renewal in reply to 1031D, 02-22-2013 10:10:26
| Jim, no way would I reuse a oring on a sleeve EVER I was talking on a flare type hyd hose application only,,, I know one thing from now on I am keeping some things to myself for sure,, getting tired of getting reamed for it |
| Jgarner
02-22-2013 10:38:43
70.139.176.83
Re: o-ring renewal in reply to Case Nutty 1660, 02-22-2013 10:29:58
| | CNT, my repoonse was not aimed at you in any shape or form. Just trying to pass on career knowledge of been there done that. Your answer seemed OK especially when qualified about hard burned rings. Your responses are always spot on!! Jim |
| Mathias NY
02-22-2013 10:03:09
69.174.58.156
| | It depends a lot on what type of material the oring is made of. Some materials will never soften once the original elasticity is lost. For most common oring materials, the shelf life is less than 10 years. I agree with Jgarner, replace it rather than try to salvage a $.50 oring. Good luck. |
| Jgarner
02-22-2013 09:45:32
70.139.176.83
| | Having had a lot of experience with elastomeric o-rings in my career I can say that the best thing to do is replace them. When an o-ring hardens it has been weakened and is no longer a vaible seal. Putting them in a "soup" to swell and soften them, and there are a number of things commercially available that will do that, only serves to make bad matters worse. Your plan IMHO is a recipe for a disasterous failure. Sorry for the negative answer but I have had too many times seen bad things happen and result in spending thousands as a result of trying to save pennies. Jim |
| Case Nutty 1660
02-22-2013 10:27:16
75.127.24.27
Re: o-ring renewal in reply to Jgarner, 02-22-2013 09:45:32
| Again I said I did this in a bind, try being 75 miles from a store to work on a leak and not have the right oring,,, I ALWAYS replace them if at all possible |
| Case Nutty 1660
02-22-2013 09:26:47
75.127.24.27
| PB Blaster will do what you are asking, soak it a few then work it with your fingers I have used it in a pinch before and never had a leak,, but the oring must be complete and not cut |
| Case Nutty 1660
02-22-2013 09:27:47
75.127.24.27
Re: o-ring renewal in reply to Case Nutty 1660, 02-22-2013 09:26:47
| want to add not to use on one that has been damaged by extreme heat and burnt hard |
| C. Amick
02-22-2013 09:23:59
173.224.156.121
| I would imagine that the ethanol in gasoline would make them swell, especially E85 gasoline. Gasoline swells the rubber o-rings on my chain saw fill cap. Don't know what kind of permanent damage you might do to the o-ring, though. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
