| Author |
[Modern View]
| Ed Turner Camrose
02-21-2013 22:02:20
142.59.176.189
My Case LA is equipped with 14-30 tires. The proper changeover is 16.9 -30. Will 18.4 work on 14 inch rims? |
| Ed Turner Camrose
02-22-2013 17:05:20
142.59.176.189
Re: Tire size in reply to Ed Turner Camrose, 02-21-2013 22:02:20
| Thanks for all your comments, they were helpful. I've seen several LA tractors in Alberta and Montana with 18.4 tires. So its not because they are rice models but for more traction on the prairies. That's my opinion anyway. |
| 1031D
02-22-2013 10:13:52
107.8.250.69
| Jim, that's about right! Closer the beads are more curve to the tread, that's why pullers go wider than design for a flatter footprint. I have 15.5-38's on my 400 diesel and they are fine, sidewalls are flat. My LA has factory 18.4-30's but the build card is missing so if it's a rice tractor is unknown. |
| Don Rudolph
02-22-2013 08:30:39
108.167.202.33
| The short answer is that they will work just fine on those rims. I have a friend who has an old Huber with 16.9-30"s on 10" factory rims. I wouldn"t recommend that. Don |
| Harold or Caseman44
02-22-2013 07:42:31
96.245.240.146
| Hi there, I saw your recent post on LA tires and rims. I have two decent tires on my 1949 Case La model tractor that I will be taking off in the future, they are 14-30 on the 14" original rims. I will be installing a pair of mounted 18.4-30 Armstrong tires mounted on 16" rims from a Case 500 diesel tractor that I had. I will sell you the La. tires if you have an interest. thanks, Harold |
| Ed Turner Camrose
02-22-2013 17:00:19
142.59.176.189
Re: Tire size in reply to Harold or Caseman44, 02-22-2013 07:42:31
| Where are you and what kind of $ are we looking at? |
| Harold or Caseman44
02-22-2013 19:45:45
96.245.240.146
Re: Tire size in reply to Ed Turner Camrose, 02-22-2013 17:00:19
| Hi there again, My tires are mounted on the original 1949 Case La rims, they both have good tread left on them. Do you need the rims as well or just the tires? The two tires and rims, ready to mount on your La are $700.00. I live in Walnutport, Pa. Depending where you live, I travel to my Son's place in Manchester, Mich. and could deliver them on my next trip there. I also will be going the eastern Tenn. come spring. Where do you live? Let me know what you are thinking. Thanks, Harold |
| Ed Turner Camrose
02-22-2013 19:57:40
142.59.176.189
Re: Tire size in reply to Harold or Caseman44, 02-22-2013 19:45:45
| I'm in Alberta Canada. The price is right but the shipping would kill me! |
| Jim in Sask
02-24-2013 15:02:47
142.165.85.93
Re: Tire size in reply to Ed Turner Camrose, 02-22-2013 19:57:40
| Ed, a friend of mine up there told me the former Case dealer at Killam (Lindseths) have a good selection of used tires and rims for Case tractors. You might give them a call. |
| Ed Turner Camrose
03-01-2013 18:02:33
142.59.176.189
Re: Tire size in reply to Jim in Sask, 02-24-2013 15:02:47
| 1031D
02-22-2013 06:26:19
107.8.250.69
| Johnpop I suggest you double check that with a a tape measure. I've been selling and installing tires half my life............. |
| Jgarner
02-22-2013 07:45:30
70.139.176.83
Re: Tire size in reply to 1031D, 02-22-2013 06:26:19
| | 1031D, logically (just trying to imagine the physics) won't that also make the tires have a "rounder" tread surface? Hence the diametrical (OD) increase to make the tractor stand a little taller. If you put a piece of paper on the table and with one hand on each side push the edges of the paper toward center the center of the paper rises up off the table. Same principle here right, or amd I thinking about this wrong? Also, you will probably know, are the 18.4 tires what they put on the rice models? I remember it had (to a little kid) very big tires. Jim |
| Adirondack case guy
02-22-2013 09:54:22
74.69.160.79
Re: Tire size in reply to Jgarner, 02-22-2013 07:45:30
| Jim, The paper example, was exactly what I was going to post, but I decided to keep my post short and sweet. LOL. I guess we're on the same brain wave today, HeHe. LOren |
| Jgarner
02-22-2013 14:27:54
70.139.176.83
Re: Tire size in reply to Adirondack case guy, 02-22-2013 09:54:22
| | Well you know what they say about great minds. (<: Jim |
| johnpop1
02-22-2013 04:50:36
96.249.14.182
| They will only look like they stand taller. If they actually stood taller, then it would suggest that the rubber in the tread area was actually stretching and if that were the case, they would grow regardless of the rim size. Growth of the diameter is an illusion. |
| Adirondack case guy
02-22-2013 05:28:14
74.69.160.79
Re: Tire size in reply to johnpop1, 02-22-2013 04:50:36
| 1031D
02-21-2013 23:54:26
107.8.250.69
| You can put 18.4's on there but they will stand taller being as the sidewalls will be pulled in at the bead. 18.4 tires are designed for a 16" rim. |
| Jimmie D. Phelps
02-22-2013 17:47:45
199.91.129.74
Re: Tire size in reply to 1031D, 02-21-2013 23:54:26
| On my 48LA when I went from the 14x30 to 15x30 (new 18.4x30) I had my rims cut and put in a three in. band. |
