Case 770 rear hood removal help
fred goodrich
OK you Case guru"s how do you remove rear hood assy on a cab tractor? Doesn"t seem to want to slide over dash and doesn"t seem to go the other way. This is the piece that is in halfway and outside halfway, under the windshield,
have to remove the cab, dash,and steering wheel and go to the rear if I remember right, still working on a rear wheel from you seeing if I can get one or two a ride
