Straw Boss
Thanks to pedalcollector, we have a list of all these tractors.
It will be on page four by tomorrow so I thought I'd move it up here. Thanks.
according to dicks price guide which doesn't have every single tractor made. here is the list of case tractor model D, DC, and 70 series tractors. I will add some if i know of a variation that is not listed.
Model D
spec cast D gas wf standard made in 2007
spec cast D 09 Pa farm showwith umbrella 1 of 750
spec cast D 2010 northland case coll 10th anniversary clamshell fenders
spec cast D firestone wheels of time 1 of 4000 released 2010.
spec cast D clamshell fenders released 2010 (no firestone tires just ertl tires.)
Dingman custom D standard made in 1986
Model DC
dingman 1983 custom made DC
1996 Spec cast DC gateway show tractor single front
1991 dingman DC with eagle hitch custom made
1995 Spec cast DC USA plowing match Case Reunion on rubber
1997 Spec Cast DC 7th annual crossroads, Normal, Il FFA
1997 Spec Cast DC with eagle hitch
1997 Spec Cast DC NF on rubber
1983 Dingman custom made DC-3 LP variation
2006 Spec cast DCS #7 high crop series, sugar cane, National farm museum.
1995 Spec cast DC-3 Special edition on steel nf
1996 Spec cast DC-3 on rubber dealer meeting special edition nf
1997 Spec cast DC-3 single front wheel fast start limited edition
2002 Spec cast DC-3 with eagle hitch
2002 spec cast DC-3 adjustable wide front
2006 spec cast DC-3 NF high detail
2006 spec cast DC-3 high detail series high crop limited edition.
2006 spec cast DC-3 gas wf
2006 spec cast DC-3 nf
2007 spec cast DC-3 nf lp
2009 spec cast DC-3 tricycle with one tire gas
1996 spec cast DC-4 wf on rubber
2002 spec cast DC-4 wf eagle hitch
2002 spec cast DC-4 on steel wf
2008 spec cast DC-4 gas wf
2008 spec cast DC-4 lp gas wf
2009 spec cast DC-4 paxton-buckley-loda show limited edition 1 of 100
2009 spec cast DC-4 wf with inverted wheels
2011 spec cast DC-3 with loader pork expo edition
2011 spec cast DC-3 with loader dealer model (only difference in these model is the pork expo decal on the loader and the box the tractor comes in)
2009 spec cast DC-3 with grain drill 09 dodge county WI tech days
some other variations not mentions the inverted wheel model also can be found in LP gas form, and they forgot about the spec cast DC that was a pulling tractor would be roughly early to mid 1990's. and a couple other custom builders have made D's and DC's.
70 series tractors
2002 ertl 970 with plow and plow dual
1970 ertl 1070 with disc, plow, wagon, and barn box
1969 ertl 1070 agri king small spindles, cab, duals
1970 ertl 1070 Agri king cab duals
1970 ertl 1070 argi king 451 cubes cab duals
1970 ertl 1070 golden harvester cab duals
1970 ertl 1070 black knight cab duals
1997 ertl 1070 agri king
2009 ertl 1070 black demonstrator limited edition 40th anniversary
1972 ertl 1170 dealer/factor promo very limited
1996 ertl 1170 2006 national farm toy show
1997 ertl 1170 with cowboy figure the last cowboy (firefox farm series)
2001 ertl 1170 cab
1972 ertl 1270 no cab
1972 ertl 1270 cab,decal error
2006 ertl 1270 white with cab
2008 ertl 1270 desert sand with cab. collector edition
1972 ertl 1270 no cab with disc, plow and wagon
1974 ertl agri king (white) 7 bottom plow, flare box wagon, and disc
1972 ertl 1370 agri king 504 turbo cab
1972 ertl 1370 agri king 504 turbo cab gold dealer award
1972 ertl 1370 agri king 504 turbo chrome plated (scarce)
2007 ertl 1370 duals, yellow, collector edition
1974 ertl 1370 agri king white no cab no model number
1974 ertl 1370 agri king large wheels cab no model numbers
1976 ertl 1370 agri king spirit of 76 cab wf light blue decal
1976 ertl 1370 agri king spirit of 76 cab wf dark blue decal
2008 ertl 1370 agri king dealer edition cab glass diecast rims duals
1998 precision engineering 1470 yellow/orange on wood plaque 1 of 300
1998 precision engineering 1470 black knight on wood plaque 1 of 200
1998 precision engineering 1470 yellow/orange on wood plaque with cab 1 of 300
there are about 8 versions of the 1470 by precision engineering the variations above also come without a plaque, there is also a industrial version, one with a snow plow, some come with duals, some with singles, he also makes 1200's that come in about 8 versions also. some on plaques are half a tractor and others are whole tractors depending on the variation.
2005 ertl 1570 toy tractor times spirit of 76
2007 ertl 1570 enclosed cab glass new tooling white.
as mentioned a 1570 will be released hopefully in june its a white 1570 with duals removable front weights, working front and rear lights, and flashers (suggested retail price is 189.00 chase unit is the same tractor only painted as a spirit of 76 should be selling between 300 and 400 dollars.)
Model D
Model DC
70 series tractors
2001 ertl 1170 cab
