TractorLinks.com
Show Parts for Model:
Re: Toy Show - Long Post
casetoyman
02-18-2013 09:51:13
This year Ertl is actually coming out with a J.I. Case precision 1570. It will be the second tractor in the Elite Series, which has working headlights and precision detail to it. it will be coming out in June if shipments arrive on time. The chase unit will be a spirit of 76. price right now for them will be between the 150 and 200 dollar mark for the white 1750, the chase spirit will be pushing $300. As for the DC with the loader from spec cast, it is only two years, there are two versions the pork expo which was released first and the shelf model which was released second, when first released they were 70 dollars for the shelf and 75 on the pork expo. yea the colors aren't correct but which limited case toys being produced one has to either go to customs or have to build your own, or paint john deere and true scale toy case colors. talking with the toy manufacturers, both Ertl and Spec Cast they seem to want to produce toys that the newest generation of collectors are demanding, so the John Deere R series, Cases MX series, and for older tractors they would rather make the 30 and 40 series and the IH 56 and 68 series and newer. One way to try and spark newer higher detail case versions would be to start a long line of collector tractors like what JD does and run it through a very large case club such as the JICCA or some other club that would be able to sell over a thousand tractors. start out with a cross motor and slowly work up through the decades of case tractors, since once the collector tractor is made the casting is ready to use to make a shelf model and a couple other variations. That's why there are so many spec cast DC's. I'm pretty sure they haven't fixed the original casting by putting brakes on it yet.
Straw Boss
02-18-2013 15:04:05
 Re: Toy Show - Long Post in reply to casetoyman, 02-18-2013 09:51:13
I saw a pretty detailed 7140 MFD. Tons of CaseIH MX tractors and lots of different CaseIH combines. So many 70 series it made my head swim. Is there a list somewhere to be had of all the new generation 70 series tractors produced? It would be nice if it had pictures of each model. I won't buy any more of them until I can figure out how many new variations and special editions are out there and I didn't have time at the show to make a list of all of them I'd seen.
If there's a check list of all the model D variations, that would be nice too. I'm sure others would like to know as well. Thanks.
pedalcollector
02-19-2013 08:14:30
 Re: Toy Show - Long Post in reply to Straw Boss, 02-18-2013 15:04:05
according to dicks price guide which doesn't have every single tractor made. here is the list of case tractor model D, DC, and 70 series tractors. I will add some if i know of a variation that is not listed.
Model D
spec cast D gas wf standard made in 2007
spec cast D 09 Pa farm showwith umbrella 1 of 750
spec cast D 2010 northland case coll 10th anniversary clamshell fenders
spec cast D firestone wheels of time 1 of 4000 released 2010.
spec cast D clamshell fenders released 2010 (no firestone tires just ertl tires.)
Dingman custom D standard made in 1986
Model DC
dingman 1983 custom made DC
1996 Spec cast DC gateway show tractor single front
1991 dingman DC with eagle hitch custom made
1995 Spec cast DC USA plowing match Case Reunion on rubber
1997 Spec Cast DC 7th annual crossroads, Normal, Il FFA
1997 Spec Cast DC with eagle hitch
1997 Spec Cast DC NF on rubber
1983 Dingman custom made DC-3 LP variation
2006 Spec cast DCS #7 high crop series, sugar cane, National farm museum.
1995 Spec cast DC-3 Special edition on steel nf
1996 Spec cast DC-3 on rubber dealer meeting special edition nf
1997 Spec cast DC-3 single front wheel fast start limited edition
2002 Spec cast DC-3 with eagle hitch
2002 spec cast DC-3 adjustable wide front
2006 spec cast DC-3 NF high detail
2006 spec cast DC-3 high detail series high crop limited edition.
2006 spec cast DC-3 gas wf
2006 spec cast DC-3 nf
2007 spec cast DC-3 nf lp
2009 spec cast DC-3 tricycle with one tire gas
1996 spec cast DC-4 wf on rubber
2002 spec cast DC-4 wf eagle hitch
2002 spec cast DC-4 on steel wf
2008 spec cast DC-4 gas wf
2008 spec cast DC-4 lp gas wf
2009 spec cast DC-4 paxton-buckley-loda show limited edition 1 of 100
2009 spec cast DC-4 wf with inverted wheels
2011 spec cast DC-3 with loader pork expo edition
2011 spec cast DC-3 with loader dealer model (only difference in these model is the pork expo decal on the loader and the box the tractor comes in)
2009 spec cast DC-3 with grain drill 09 dodge county WI tech days
some other variations not mentions the inverted wheel model also can be found in LP gas form, and they forgot about the spec cast DC that was a pulling tractor would be roughly early to mid 1990's. and a couple other custom builders have made D's and DC's.
70 series tractors
2002 ertl 970 with plow and plow dual
1970 ertl 1070 with disc, plow, wagon, and barn box
1969 ertl 1070 agri king small spindles, cab, duals
1970 ertl 1070 Agri king cab duals
1970 ertl 1070 argi king 451 cubes cab duals
1970 ertl 1070 golden harvester cab duals
1970 ertl 1070 black knight cab duals
1997 ertl 1070 agri king
2009 ertl 1070 black demonstrator limited edition 40th anniversary
1972 ertl 1170 dealer/factor promo very limited
1996 ertl 1170 2006 national farm toy show
1997 ertl 1170 with cowboy figure the last cowboy (firefox farm series)
2001 ertl 1170 cab
1972 ertl 1270 no cab
1972 ertl 1270 cab,decal error
2006 ertl 1270 white with cab
2008 ertl 1270 desert sand with cab. collector edition
1972 ertl 1270 no cab with disc, plow and wagon
1974 ertl agri king (white) 7 bottom plow, flare box wagon, and disc
1972 ertl 1370 agri king 504 turbo cab
1972 ertl 1370 agri king 504 turbo cab gold dealer award
1972 ertl 1370 agri king 504 turbo chrome plated (scarce)
2007 ertl 1370 duals, yellow, collector edition
1974 ertl 1370 agri king white no cab no model number
1974 ertl 1370 agri king large wheels cab no model numbers
1976 ertl 1370 agri king spirit of 76 cab wf light blue decal
1976 ertl 1370 agri king spirit of 76 cab wf dark blue decal
2008 ertl 1370 agri king dealer edition cab glass diecast rims duals
1998 precision engineering 1470 yellow/orange on wood plaque 1 of 300
1998 precision engineering 1470 black knight on wood plaque 1 of 200
1998 precision engineering 1470 yellow/orange on wood plaque with cab 1 of 300
there are about 8 versions of the 1470 by precision engineering the variations above also come without a plaque, there is also a industrial version, one with a snow plow, some come with duals, some with singles, he also makes 1200's that come in about 8 versions also. some on plaques are half a tractor and others are whole tractors depending on the variation. 2005 ertl 1570 toy tractor times spirit of 76
2007 ertl 1570 enclosed cab glass new tooling white.
as mentioned a 1570 will be released hopefully in june its a white 1570 with duals removable front weights, working front and rear lights, and flashers (suggested retail price is 189.00 chase unit is the same tractor only painted as a spirit of 76 should be selling between 300 and 400 dollars.)
Straw Boss
02-19-2013 14:08:05
 Re: Toy Show - Long Post in reply to pedalcollector, 02-19-2013 08:14:30
OMG !!! Its worse than I thought. I'll have to drag mine out of storage and see which ones I have. I was afraid I was missing a few but maybe I'm missing most of them. Thank you for the list. Sure will help me and I'm sure others to sort them all out.
casetoyman
02-19-2013 18:13:03
 Re: Toy Show - Long Post in reply to Straw Boss, 02-19-2013 14:08:05
Yea there are a lot of them as you can see but just think they made 23 variations of the case 580 construction backhoe alone.
