TractorLinks.com
Show Parts for Model:
Re: 2090 question
mEl
02-13-2013 04:33:32
The limiter disc on the flywheel is a set tension non disengagable clutch and has nothing to do with stopping or starting the motion of the tractor, The lining wearing out is a very rare occourance but the spring centers are prone to failure, as were the 70 series. Being a set tension clutch it's purpose is to just move a bit under heavy shock loads but never "slip" per sae.
The actual clutching is done buy C2 clutch in the power shift and is very durable. Most powershift problems in any power shift tranny Case built were caused by sheared C2-C3 carried bolt or a disregard for maintanance causing sticky pilot spools.
They are a good tractor, but If I were not a Case man I would have a very good one check it out for you, If you had to rent a good Case Ag tractor tech for a couple hours it would be money well spent, and this goes for most purchases ,not just rtractors.
There is a general lack of understanding of the function of the powershift and it's interaction with the main hydraulic system that a good tech will have to ascertain the condition of the tractor.
mEl
Adirondack case guy
02-13-2013 05:15:06
 Re: 2090 question in reply to mEl, 02-13-2013 04:33:32
As always Mel in dead on with his comments. Anorher point to research if the 2090 is an early Sn#, is whether it has had the extensive rearend differential upgrades installed in it. This will be a paper chase as there is no way to identify the rework from the outside, other than listening carefully while turning tight circles in both directions, watching and listening. for any binding or jerking. You can also jack up one rear wheel and rock it back and forth to check for excessive gear lash. Loren
1370rod
02-13-2013 05:47:56
 Re: 2090 question in reply to Adirondack case guy, 02-13-2013 05:15:06
Loren, part of the update for the 20-2290 tractors included the addition of a ring+pinion lube line. This lube line is mounted on the trans cover top toward the back of course. It is difficult to see once the tractor is assembled, but is visible IF you know what your looking for. Add about 30 years of dirt and grime to the the top and its nearly impossible, but if a person is really determined it can be figured out if its there or not. Rod.
