Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 350 and late DC rpm?
Jgarner
02-12-2013 11:46:16
Thanks Gene and you mentioned something that had never really crossed my mind and that is hand cranking and why later model tractors did not offer that option.
Higher compression engines eliminated hand cranking. I remember hand cranking our 1 ton Model T truck and I know it was pretty low compression just had never put 2 and 2 together until just now as to why mid 50s on did not have hand crank capabilities and I knew that diesels could not be hand cranked due to high compression and just didn't think about gasoline engines as they got bigger with higher compression and more horsepower. I always try to learn something new every day and this is my new bit of knowledge!
Jim
C. Amick
02-13-2013 09:50:00
 Re: 350 and late DC rpm? in reply to Jgarner, 02-12-2013 11:46:16
Did Case make any tractors with compression releases to assist hand cranking?
LenND
02-13-2013 12:30:22
 Re: 350 and late DC rpm? in reply to C. Amick, 02-13-2013 09:50:00
My 58 900B deisel has a compression release lever. Sure helps if you have a little weak battery.
Gene Dotson
02-12-2013 13:09:52
I am sure that reliable sterters and batteries had a big part in the demise of hand cranks. Safety is another thing. I have a scar on my left forearm from trying to crank the LA. I finally broke down and had my stock generator rebuilt to 12 volt and a 12 volt battery. Burnt up 1 starter and 2 starter switches trying to start it on 6 volt. Even group 4 battery and 4-0 battery cables barely started it. Cranks over very good now.
Gene
Jgarner
02-13-2013 08:24:18
 Re: 350 and late DC rpm? in reply to Gene Dotson, 02-12-2013 13:09:52
I vividly remember watching Dad cranking himself silly on the LA after it had set all winter. After it statred and had run a while it would restart with little cranking. We used ours for spring plowing and other assorted chores off and on that took big HP. Dad wouldn't spring for a battery to use just 3 or 4 times a year. He also used 8V batteries in all of our 6V systems for that little extra kick (tweaked VR to about 9V output). Just had to replace light bulbs more often.
Copyright © 1997-2015 Yesterday's Tractor Co.
