| Case Tractors Discussion Forum |
Topic: Re: 350 and late DC rpm?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Gene Dotson
02-12-2013 11:21:48
69.88.222.62
LA displacement remained the same at 403 Cu.In. with 4 5/8 inch bore. After market kits were available for 4 3/4 and 4 7/8 inch. Have 4 7/8 pistons in my LA for 448 Cu.In. Stock bore was unchanged from L to LA. LA did offer a high compression piston in later models, if you believe 5.7 to 1 compression was high. My LA with LP head is about 8.0 to 1 compression and you do not hand crank it.VAC did not increase bore either. Gene |
| Jgarner
02-12-2013 11:46:16
70.139.176.83
Re: 350 and late DC rpm? in reply to Gene Dotson, 02-12-2013 11:21:48
| | Thanks Gene and you mentioned something that had never really crossed my mind and that is hand cranking and why later model tractors did not offer that option. Higher compression engines eliminated hand cranking. I remember hand cranking our 1 ton Model T truck and I know it was pretty low compression just had never put 2 and 2 together until just now as to why mid 50s on did not have hand crank capabilities and I knew that diesels could not be hand cranked due to high compression and just didn't think about gasoline engines as they got bigger with higher compression and more horsepower. I always try to learn something new every day and this is my new bit of knowledge! Jim |
| C. Amick
02-13-2013 09:50:00
173.224.156.121
Re: 350 and late DC rpm? in reply to Jgarner, 02-12-2013 11:46:16
| Did Case make any tractors with compression releases to assist hand cranking? |
| LenND
02-13-2013 12:30:22
74.207.160.118
Re: 350 and late DC rpm? in reply to C. Amick, 02-13-2013 09:50:00
| My 58 900B deisel has a compression release lever. Sure helps if you have a little weak battery. |
| Gene Dotson
02-12-2013 13:09:52
69.88.222.62
| | I am sure that reliable sterters and batteries had a big part in the demise of hand cranks. Safety is another thing. I have a scar on my left forearm from trying to crank the LA. I finally broke down and had my stock generator rebuilt to 12 volt and a 12 volt battery. Burnt up 1 starter and 2 starter switches trying to start it on 6 volt. Even group 4 battery and 4-0 battery cables barely started it. Cranks over very good now. Gene |
| Jgarner
02-13-2013 08:24:18
70.139.176.83
Re: 350 and late DC rpm? in reply to Gene Dotson, 02-12-2013 13:09:52
| I vividly remember watching Dad cranking himself silly on the LA after it had set all winter. After it statred and had run a while it would restart with little cranking. We used ours for spring plowing and other assorted chores off and on that took big HP. Dad wouldn't spring for a battery to use just 3 or 4 times a year. He also used 8V batteries in all of our 6V systems for that little extra kick (tweaked VR to about 9V output). Just had to replace light bulbs more often. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
