denverslim
It should be obvious to all by now that when it comes to understanding wiring, I'm somewhat handicapped! I'm asking for help from the forum.
The wiring diagrams all clearly show the "orange" feed wire from the generator going to one side of the circuit breaker. This breaker is also a link from the "red" or HOT wire from the starter to the key switch. Now, what this does is, when the engine is started, the generator feeds juice back to the starter solenoid, causing the starter drive to engage. Thus the drive begins to push into the flywheel while the engine is running. THIS OBVIOUSLY IS A PROBLEM.
I've racked my feeble brain and strained my eyes way too long looking at the diagrams, I've disconected the charging wire to make everything work but the charging system. Where am I wrong?
Thanks in advance for your patience and expertise...slim
