TractorLinks.com
Show Parts for Model:
Re: 1370rod/casenutty/other LGT guys
Case Nutty 1660
02-11-2013 06:56:22
you need to compare the spec #'s to see if the one you are looking at has the same shaft size throttle linkage ect to be sure it would fit, the pto clutch on a Case tractor is a bolt on piece but I would be more concerened if the rear crankshaft is the same and I am not sure what you will use it for but a 10hp is weak compared tot he 14hp unit, can yours be overhauled or is the block junk? the Kolhers when boared do live a long life and are worth repairing in my mind if possible cnt
caseanonymous
02-11-2013 09:12:16
 Re: 1370rod/casenutty/other LGT guys in reply to Case Nutty 1660, 02-11-2013 06:56:22
Thanks for quick response. My engine is using alot of oil and the governor is now giving issues its just time for a rebuild. This tractor is well used and I got it for free from a guy who just wanted to get rid of it. It is in pretty rough shape I was thinking if it was an easy fit I'd do it or else probably just part it out to keep my other ones moving and mowing etc. I totally agree its worth rebuilding too this was just a little different deal here. P.S will a sleeve hitch from a 446 fit a 224?
Case Nutty 1660
02-11-2013 09:24:12
 Re: 1370rod/casenutty/other LGT guys in reply to caseanonymous, 02-11-2013 09:12:16
no the 200 series are a shorter hitch due to the tire heights
