Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: case 310 utility seems to run wide open
casecollectorsc
02-10-2013 12:13:18
Sometimes the carb. will ice up due to moisture in the air and freeze the throttle shaft in the wide open position. BTDT.
ChuckMA
02-10-2013 13:34:20
 Re: case 310 utility seems to run wide open in reply to casecollectorsc, 02-10-2013 12:13:18
Thanks casecollectorsc. Just ran it again this afternoon still no change it was 36F and ran for an hour and no change tomorrow warmer in the 40's will try again if no luck maybe try quartz heater to thaw it out as i don't keep my tractors in a heated shed.
Chuck
Firemanjohn
02-10-2013 17:19:07
 Re: case 310 utility seems to run wide open in reply to ChuckMA, 02-10-2013 13:34:20
Can you stand next to it and manually work the butterfly back to an idle? hat would tell you linkage or less likely internal carb issue.
Jeff B.
02-11-2013 19:42:56
 Re: case 310 utility seems to run wide open in reply to Firemanjohn, 02-10-2013 17:19:07
A substantial vacuum leak would make it run like that.
