Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Case DC rim
[Return to Forum]
Allis Fields
02-10-2013 10:30:34
71.87.6.200
What type of rims fit the rear of a DC Case ?
The tractor is going to be used as a farm stock puller and the owner would like to put some 15.5-38 tires on the back. Also how do you turn the rpms up. The local club allows 3000 rpm's. Not that it is ever going to see that but it would be nice to get some extra power.
[Reply]   [No Email]
Fred Goodrich
02-11-2013 04:21:30
108.176.84.251
 Re: Case DC rim in reply to Allis Fields, 02-10-2013 10:30:34
They are called drop center.
[Reply]  [No Email]
dboll
02-10-2013 12:02:47
209.23.168.201
H/M IH or A/B?G jd rims will fit, either have your rims widened to 14 or 15 inches or buy new 14' drop center rims, if you are going to use the cast centers, you can also weld lugs to a 14" double bevel and bolt them on the castings or use 9 bolt pressed wheels, increasing the governor spring tension will get you about 1450rpm's for more a light spring on the throttle shaft or a piece of wire around the gov. spring will do the job, I would not want to take a stock dc over 1800 or so unless I knew the condition of the engine and flywheel, remember-there's no replacement for displacement
[Reply]  [No Email]
1031D
02-10-2013 11:51:59
107.8.250.69
For 15.5-38's your going to need a double drop base rim. I would get a W14x38 rim. You want more power out of it do not touch the governor. Put 4 1/16" pistons in it with a propane head.
[Reply]  [No Email]
1948 mm
02-10-2013 11:36:37
208.71.220.136
Ivs seen a D crank and it does not look strong enough or balanced enough to handle 3000 rpm. Higher compression in that engine is going to give you the most hp gain for the least amount of money.
[Reply]  [No Email]
wilson ind
02-10-2013 11:30:54
173.15.67.45
The DC developer its max torque at lower rpm . It just might be weaker at above 2000. My CC puller does best at 1500 or lower. Just no sub for cubic inch and long stroke. Along the idea of size does matter!!!!
[Reply]  [No Email]
Don Rudolph
02-10-2013 10:47:54
198.190.115.188
I don't know the proper terminology for the rim design but I've heard them called several different things, double bevel, triple bevel, double offset, etc. Farmall M's used the same rim so all you have to tell a tire or salvage place is Farmall M rims and they'll know. To turn up the RPM's there are two adjusting nuts on the throttle linkage right behind the oil filter cannister. Just shorten the linkage to increase the R's. Or the fast and dirty way is to wire the governor spring tight like we used to do to blow silage with a DC. Don
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
