its a 1980 one owner tractor
Nice looking tractor with the bracket that puts the steps at a slight angle. Is there and stickers or paper work that mentions updates being done? just curious if any other dealers had done that. Rod.
Thanks yeah the updates been done all with paperwork also the trans just been gone through also the heads on engine also it has 4700 orginal hours on it just a question about the powershift what do i not need to do to mess it up etc cause powershift is new to me
Sounds like a good tractor. The best thing you can do for the powershift is keep trans oil and filters clean. Only use the HP hyd. filter kit, there is a cheap set so ask for the HP set. Also when shifting the powershift up or down do so at reduced RPM's and shift down by hand one at a time, try not to stab the clutch down which forces it through two shifts. Treat it good and it will treat you good, enjoy your tractor, Rod.
Thats nice looking tractor. I would only use Case Hytran Oil in the hydraulics/rear end.
I bought a 1370 about 6 years ago and switched oil to another brand and about ruined the tractor. The oil eat the glue from underneath the fiber discs on the clutch plates
Rod1370 said to use the case filters, i also agree
