Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Wiring help 711B
rvirgil_KS
02-05-2013 13:51:04
Wire from alternator and supply feeds to switches and gauges all go to one side of ammeter. Other side of ammeter goes to battery.
Ammeter tells you if battery current is going into the battery (charge) or coming out of battery (discharge).
Move your alternator wire to the bottom pole of ammeter. Battery charge current must go through the alternator for it to indicate.
rvirgil_KS
02-05-2013 15:22:35
 Re: Wiring help 711B in reply to rvirgil_KS, 02-05-2013 13:51:04
Typo...should read
Battery charge current must go through the AMMETER for it to indicate.
Dodgeit
02-05-2013 17:43:07
 Re: Wiring help 711B in reply to rvirgil_KS, 02-05-2013 15:22:35
Thanks for the help, and explaination.
Dodgeit
02-10-2013 14:37:17
 Re: Wiring help 711B in reply to Dodgeit, 02-05-2013 17:43:07
Update. Changed the wire to the bottom pole. No change in operation of Ammeter. Did some more looking at the back side of the meter, and the top pole is marked - minus. So the way it's wired now, the wire from battery is to the top pole. Wire to starter switch, light switch and fuel gauge. Alt wire is unhooked at this time. With engine running, alt. wire is putting out 15+ volts as checked with a voltmeter.
Copyright © 1997-2015 Yesterday's Tractor Co.
