511 manifold
Anonymous-0
I am looking for a manifold for a 511 Case the one on my tractor is different from any I have found.
I am looking for a manifold for a 511 Case. My manifold is different than any I have found.Iwas told at a salvage yard that a few have this Oddball manifold. Iwandered if anybody knew anything about this. The manifold is shorter where it goes down to the carbereter and the carb bolts are wider apart and the hole is bigger inside for abigger carb. I have talked to several parts places and salvage yards and the one guy was theonly one that knew what I was talking about. If any one could help I would appretiate it.
The 400b, 500b, and 600b all used the same manifold with the larger carb bolt spacing. The 300, 200b, 300b and 350 all were the same and had the smaller bolt spacing. If it has a real short vertical intake runner it could be for an lp tractor. Lee
I tried a new aftermarket exhaust manifold with my old intake and it would not line up right. The exhaust sets up above the intake and doesn"t line up with the holes in the head and the bolt holes.
Here is a pic of ours, Sn#6097184. Hope this is some help.
Loren
