Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 970 Case Hydraulic Help
02-04-2013 16:19:33
As John S has mentioned a air leak could be causing the problem. A simple flow test of the hyd pump would tell you what to service, pump or hyd valve. We can suggest items to look for but they would be just that, guesses. The flow test is the proper start to this repair, but if there is no way to have one done you can start by removing the pump and inpecting the seal. I just hate to see you spend time and money just guessing, Rod.
02-05-2013 09:49:19
 Re: 970 Case Hydraulic Help in reply to 1370rod, 02-04-2013 16:19:33
Thanks for the quick feedback. It will probably be next month before I can get to this project. Sound running tractor that is still around for mostly just sentimental reasons. No urgent need for it at the moment, but would like to keep it going as long as possible; especially if it's only simple/inexpensive fixes. I will check back in later to post what the result was.
