Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 970 Case Hydraulic Help
[Return to Forum]
Tammarine
02-04-2013 13:35:51
107.36.78.94
Need some help resolving hydraulic issues with a 970 Case 8 spd Manual Shift. Zero to very little hydraulic pressure to remotes, steering, and three point even when engine is at full throttle. However, PTO seems to work just fine even on a maximum work load so not sure that it is the pump. After trying to generate pressure on the remotes at full throttle, there appears to be a lot of air foaminess in the oil when viewing the glass indicator bubbles on the side of the transmission housing. If the pump is sucking air at the intake, then why does the PTO perform ok? Have seen similar threads at this site previous, and wondering if someone here might give me some clues before I tear this thing down and go after it.
[Reply]   [No Email]
1370rod
02-04-2013 16:19:33
174.125.224.243
Re: 970 Case Hydraulic Help in reply to Tammarine, 02-04-2013 13:35:51
As John S has mentioned a air leak could be causing the problem. A simple flow test of the hyd pump would tell you what to service, pump or hyd valve. We can suggest items to look for but they would be just that, guesses. The flow test is the proper start to this repair, but if there is no way to have one done you can start by removing the pump and inpecting the seal. I just hate to see you spend time and money just guessing, Rod.
  [Reply]  [No Email]
Tammarine
02-05-2013 09:49:19
107.38.194.234
Re: 970 Case Hydraulic Help in reply to 1370rod, 02-04-2013 16:19:33
Thanks for the quick feedback. It will probably be next month before I can get to this project. Sound running tractor that is still around for mostly just sentimental reasons. No urgent need for it at the moment, but would like to keep it going as long as possible; especially if it's only simple/inexpensive fixes. I will check back in later to post what the result was.
  [Reply]  [No Email]
John Saeli
02-04-2013 14:31:01
66.66.16.240
I had a similar problem with an 1175. Turned out to be the rubber sealing ring between the pump & inlet port. Simply pull the pump & inspect or replace. The PTO only requires about 200+ pounds of captured oil press. to work.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
