Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Low idle hunting / surging
Gene Dotson
02-04-2013 12:17:07
Set your governor to carburetor rod. With engine off and throttle wide open, need to adjust the governor rod for 1/16 inch from wide open stop.
02-04-2013 15:53:43
 Re: Low idle hunting / surging in reply to Gene Dotson, 02-04-2013 12:17:07
Gene, thanks for that suggestion. This is a pulling tractor, so the rpms are a bit higher than stock. Is the adjustment still the same at 2200 rpms as it is at 1650? Or set it at 1650 and it's set for upper rpms as well?
02-04-2013 16:46:25
 Re: Low idle hunting / surging in reply to Dodgeit, 02-04-2013 15:53:43
length of the rod has very little or nothing to do with rpm's, spring tension overcoming the governor weights does, shortening the rod a little at a time should cure it
