Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 580 fork lift power shuttle
[Show Entire Topic]  [Return to Forum]
2290
02-03-2013 04:59:25
71.169.102.243
Case Nutty,
It is a plain 580. And yes I understand it will leak air before oil,But this little hole is inside of the hollow shaft. It is about 1" from the needle bearing.I hope this helps Case Nutty. I have worked on many 580 C thru k over the past number of years, But I,m not sure about this little hole it makes no sense because oil will come out when pressure is applied. Thank you very much for any help.
Thank you,
Marlin
[Reply]   [No Email]
Case Nutty 1660
02-03-2013 06:42:24
75.127.24.27
Re: 580 fork lift power shuttle in reply to 2290, 02-03-2013 04:59:25
Marlin, I will dig out my SM manual later and see if it will shed some light on your problem, I have worked on the 580CK/580B units a lot but it has been a day or two since I have been it too one but I think I remember the hole you are speaking of, on the tractor units they had a plug that was installed if a pto was not used to keep the oil going in the correct place not sure if a forklift used the same shaft but is possible for sure, is this a problem that just started or are you trying to fix something some one else has been into before? I run into this a lot I will let you know what I find cnt
  [Reply]  [No Email]
2290
02-03-2013 10:51:33
71.169.102.243
Re: 580 fork lift power shuttle in reply to Case Nutty 1660, 02-03-2013 06:42:24
Dear Case Nutty,
I do have a s.n. it doesn't show a hole there. This hole is about the size of a ball point pen tip and located about 1" from the needle bearing in the end of shaft.Yes,it has been worked on before by someone that patch it. This guy bought it at a sale CHEAP and it has not worked right since. I think he bought it not knowing what to look for. I have worked on 580ck & B models in the past. But I do not remember of tiny hole on that inter tube in the shaft. Because if it was in forward gear for even 10 min. it would fill the shaft with oil & some pressure. I’m having low pressure in forward
  [Reply]  [No Email]
Case Nutty 1660
02-03-2013 11:44:15
75.127.24.27
Re: 580 fork lift power shuttle in reply to 2290, 02-03-2013 10:51:33
does it look like a machined hole or is it a bad spot in the casting that finally showed up? can you post a pic of it by chance? you may have to find a used replacement shaft to confirm sorry I am not much help I do much better with it in my hands
  [Reply]  [No Email]
2290
02-03-2013 13:35:37
71.169.102.243
Re: 580 fork lift power shuttle in reply to Case Nutty 1660, 02-03-2013 11:44:15
Case Nutty,
Thank you very much for your effort in trying to solve my issue. It,s really nice to share knowledge with guys on the forum.I will let you know what I come up with. My guys will put back together tomorrow sometime.I rebuilt the whole unit.
Thank You,
Marlin
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
