| Case Tractors Discussion Forum |
Topic: 580 fork lift power shuttle
[Return to Forum]
| Author |
[Modern View]
| 2290
02-02-2013 16:25:59
72.72.245.106
Hi, I'm was wondering if anyone knows,if the power shuttle shaft should have a little hole on the inside. When I put air in the forward clutch pack there is air coming out that little hole. It is about 1" from the bottom of the needle bearing. I am having problems with it. I would like a call please, because it is to difficult to explain. Thank You, Marlin |
[Reply] [No Email] | |
| Case Nutty 1660
02-02-2013 16:43:24
75.127.24.27
Re: 580 fork lift power shuttle in reply to 2290, 02-02-2013 16:25:59
| is this a plain 580 or a C/D ect? also not completely sure where you are talking but the shuttle packs are pressure lubed so as to keep the plates running in oil air will really leak when applied where as oil is much thicker,,just my thoughts,also what problem are you having? need a little more info cnt |
| 2290
02-03-2013 04:59:25
71.169.102.243
Re: 580 fork lift power shuttle in reply to Case Nutty 1660, 02-02-2013 16:43:24
| Case Nutty, It is a plain 580. And yes I understand it will leak air before oil,But this little hole is inside of the hollow shaft. It is about 1" from the needle bearing.I hope this helps Case Nutty. I have worked on many 580 C thru k over the past number of years, But I,m not sure about this little hole it makes no sense because oil will come out when pressure is applied. Thank you very much for any help. Thank you, Marlin |
| Case Nutty 1660
02-03-2013 06:42:24
75.127.24.27
Re: 580 fork lift power shuttle in reply to 2290, 02-03-2013 04:59:25
| Marlin, I will dig out my SM manual later and see if it will shed some light on your problem, I have worked on the 580CK/580B units a lot but it has been a day or two since I have been it too one but I think I remember the hole you are speaking of, on the tractor units they had a plug that was installed if a pto was not used to keep the oil going in the correct place not sure if a forklift used the same shaft but is possible for sure, is this a problem that just started or are you trying to fix something some one else has been into before? I run into this a lot I will let you know what I find cnt |
| 2290
02-03-2013 10:51:33
71.169.102.243
Re: 580 fork lift power shuttle in reply to Case Nutty 1660, 02-03-2013 06:42:24
| | Dear Case Nutty, I do have a s.n. it doesn't show a hole there. This hole is about the size of a ball point pen tip and located about 1" from the needle bearing in the end of shaft.Yes,it has been worked on before by someone that patch it. This guy bought it at a sale CHEAP and it has not worked right since. I think he bought it not knowing what to look for. I have worked on 580ck & B models in the past. But I do not remember of tiny hole on that inter tube in the shaft. Because if it was in forward gear for even 10 min. it would fill the shaft with oil & some pressure. I’m having low pressure in forward |
| Case Nutty 1660
02-03-2013 11:44:15
75.127.24.27
Re: 580 fork lift power shuttle in reply to 2290, 02-03-2013 10:51:33
| does it look like a machined hole or is it a bad spot in the casting that finally showed up? can you post a pic of it by chance? you may have to find a used replacement shaft to confirm sorry I am not much help I do much better with it in my hands |
| 2290
02-03-2013 13:35:37
71.169.102.243
Re: 580 fork lift power shuttle in reply to Case Nutty 1660, 02-03-2013 11:44:15
| | Case Nutty, Thank you very much for your effort in trying to solve my issue. It,s really nice to share knowledge with guys on the forum.I will let you know what I come up with. My guys will put back together tomorrow sometime.I rebuilt the whole unit. Thank You, Marlin |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
