Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Newer VAC Throttle
Connor9988
02-02-2013 15:10:09
Hello everyone.
My VAC has the throttle mounted on the steering column and it is really sloppy. Aside from the notch on the lever being worn off (we welded a little on it and have somewhat reformed it) the spring and rubber bushing on it are fairly worn out.
Does anyone know of any new ones that are around or if there are aftermarket kits for it?
Thanks
1031D
02-03-2013 05:52:19
 Re: Newer VAC Throttle in reply to Connor9988, 02-02-2013 15:10:09
Ah ha! I was thinking the old style. I don't know if my butt would let that Bostrum seat go, but there's one on ePay. I have a spare late dash for parts. Let me look at it.
Connor9988
02-03-2013 08:31:42
 Re: Newer VAC Throttle in reply to 1031D, 02-03-2013 05:52:19
Haha. I can understand that. I think mine should keep the old one anyways (I dont think my rump would mind too much either.)
Thanks for the help!
1031D
02-02-2013 19:53:42
Are you talking the cast throttle lever? Those are tightened by a bolt and spring, no rubber parts. I have good used if needed.
Connor9988
02-02-2013 21:24:40
 Re: Newer VAC Throttle in reply to 1031D, 02-02-2013 19:53:42
this is a picture of a VAC with the same kind of throttle lever that mine has.
(Same picture that I used on my "Seat" post.)
Connor9988
02-02-2013 21:14:42
Mine has the newer throttle which is bolted to the steering column. Its made from stamped steel and has "teeth."
