TractorLinks.com
Show Parts for Model:
Re: 6 volt charging system questions.
1031D
02-02-2013 06:33:52
Yes it is positive ground. You would just hook positive to positive and negative to negative. There's not really a backwards.
TimBinWV
02-02-2013 06:40:45
 Re: 6 volt charging system questions. in reply to 1031D, 02-02-2013 06:33:52
Thanks, 1031D. I guess the battery I have is just junk, as I had it on a trickle charger for 24hrs and it shows no sign of taking a charge. Battery looks new, One more question. Will it hurt a 6 volt battery to charge it with 12 volts-low amps to try to get it recharge?
Jerry W
02-02-2013 19:40:37
 Re: 6 volt charging system questions. in reply to TimBinWV, 02-02-2013 06:40:45
Iypically charging a 6v battery with a 12v charger won't hurt but it kind of matters how low is low on your voltage selector. You could possibility 'boil over' your battery if you left it on there long enough. I would try it and see what happens after a little bit and keep an eye on the amp gauge.
Jerry
j hikemper
02-02-2013 07:10:38
tim , probably should search archives about this ,i have jumped 6volts with 12 many times ,i would not give up on battery yet ,, i have 4 chargers around here ,all came from auction /yardsales , probably ought to toss 3 of them ../after readin g horrorstories of fires .. the poor chargers work only on the low amp side like a triklle ,,
