| Author |
[Modern View]
| 71ford100
02-01-2013 09:13:13
70.196.201.78
 Went to an old junkyard and this Case was in there. The serial tag was gone the block is cracked otherwise it is pretty complete. The owner said we would dell tractors out whole. |
[Reply] [No Email] | |
| JimEvans
02-01-2013 17:00:03
66.185.0.208
Re: Case CC with a Waukesha and a single front wheel. in reply to 71ford100, 02-01-2013 09:13:13
| A single front on a chicken roost RC is fairly rare. At least I haven't seen any. It is probably more rare than dual front wheels on a over-the-top RC. And, yes, you push the clutch lever forward to engage. |
| dboll
02-01-2013 15:14:36
209.23.168.121
| it'a an RC, for the money it will take to fix you can buy a runner but it would be worth something as a parts donor |
| casenut1
02-01-2013 14:08:36
107.8.39.45
| where is this located at. |
| 71ford100
02-03-2013 10:26:39
70.196.200.250
Re: Case CC with a Waukesha and a single front wheel. in reply to casenut1, 02-01-2013 14:08:36
| The tractor is between Loveland and Greeley Colorado. |
| dboll
02-02-2013 07:07:08
209.23.168.41
| Bendover, Utah |
| oleclint
02-01-2013 13:02:43
69.8.14.205
| Look at the rear axel on this R C. Then look at a rear axel on a CC , you will see that they are not even close to beig the same. clint |
| Racine
02-01-2013 12:47:50
121.72.224.175
| C.Amick I note with interest you note regarding the clutch lever movement on a model "RC" tractor.No the clutch lever on the model's "L", " C ", early " D " and " RC" tractors are ALL mounted on the right hand side of the transmission, and YES they are all puled back to engage, and pushed forward to disengage. Then with the Falmbeau Red tractors, the levers were mounted on thje left side of the transmission - these were pushed forward to engage and pulled back to disengage the clutch. I am sure that a Waukesha engine would NOT fit up to a model "CC" or "C" tractor Transmissin housing. Hope that this clears up your query. Regards Alan T. Lewis Christchurch NEW ZEALAND |
| casenut1
02-01-2013 14:07:10
107.8.39.45
Re: Case CC with a Waukesha and a single front wheel. in reply to Racine, 02-01-2013 12:47:50
| Afraid i have to disagree with you.i have a 36 and a 38 RC and you push forward to engage the clutch. when you pull back that engages the belt pulley brake pad on the pulley. |
| Bud Tierney
02-01-2013 09:52:22
65.102.18.48
| Early Rs came with Wauk FK or FKJ (35-6??) later replaced by FC, sometimes shown as the FC9T (the "9T" being the works code for accessories etc (ign, carb etc)... |
| Harvey 2
02-01-2013 09:36:49
74.128.149.135
| Are you sure it isn't and RC instead of a CC ? I had an RC several years ago that looked a lot like it. |
| L.C.Gray
02-01-2013 09:35:44
166.137.119.16
| That's an RC, smaller than a CC. Looks like a '37 or '38 model. |
| C. Amick
02-01-2013 12:24:32
173.224.156.121
Re: Case CC with a Waukesha and a single front wheel. in reply to L.C.Gray, 02-01-2013 09:35:44
| Did the hand clutch push forward to engage on an RC like it did on the SC? |
