Case 750 crawler oil pressure
Hi everyone. Have a question probably beyond my abilities. A case 750 crawler older model. Was idling and lost oil pressure. Owner caught it and shut down but needs repair. I am considering trying to repair and am hoping this might be done. Anyone done this repair or should I run. Diesel. Any help appreciated.
Jason
Jason;
The 750 uses the same engine as the 700, 800 and 730 tractors. It is a 267 cu.in. diesel. Pretty straight forward engine to work on. If the oil pan can be removed with the engine in the tractor, the oil pump can be easily accessed. Can check for stuck relief valve or possible broken drive shaft. Also check for plugged oil passages.
Gene
