Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Eagle hitch and loader valves on same hydraulics?
DKase
01-31-2013 05:45:29
Plumb your pump to your loader valve, the return from your loader valve to the Eagle hitch valve, and the return from the Eagle hitch to the torque tube return. Circuits need to be in series, not parallel. Flow always takes the route of least resistance. Some loader valves are not designed to take pressure on the return port of the valve. If your loader valve develops leaks it may need to be replaced with a valve designed for "power beyond". Your system is low pressure so you should get by with it.
