Hi,
What is the correct way to hook up both the Eagle hitch and a additional 2 spool valve for a loader on a VAC?
My project tractor essentially has the output from the pump wye'd to both the loader valve and eagle hitch valve. The output from both are also wye'd to the return line. At the Eagle hitch there are shut off's at both the input and output.
The loader works fine when the Eagle hitch shut offs are closed, however when I open the Eagle hitch shut offs the hydraulics are very sluggish. Engaging the loader valves will affect the Eagle hitch and vise versa.
Is there simply not enough pressure to opperate both systems? Or the 2 systems be hooked up differently?
Thanks,
Mike
Thanks,
Mike
