| Case Tractors Discussion Forum |
Topic: Re: Eagle hitch and loader valves on same hydraulics?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Christopher Mikesell
01-30-2013 21:13:12
76.226.26.182
The hydraulic system works by circulating oil continuously. When you need to move a cylinder, you direct the flow of oil into a cylinder and it puts a load on the pump. The pump stays loaded until you either shut off the lever or the pressure gets high enough that the fluid flows through a safety relief valve (like when hitting the end of travel on the cylinder). In the original eagle hitch system, the hydraulic fluid freely flows from the pump through the control valve and back to the pump. When you raise the lift, either partial or the full flow of the pump is directed to the piston which lifs the hitch, depending on how far you push the lever. Full, unrestricted, low-pressure flow is restored when you return the lever to neutral. Thus, if you leave the two valves open and try to work the loader, then the fluid is free to circulate through the eagle hitch circuit with little back pressure. This means that you will get almost no flow to the loader valve. Try this: open both valves and fully raise the eagle hitch while leaving the eagle hitch lever in the full up position, and simultaneously try to operate the loader. Once the eagle hitch raises all of the way up, the loader should work normally. This just demonstrates how the system works. Most tractor hrdraulic systems have a hydraulic priority. Using the valve closest to the pump in the hydraulic circuit will render all of the other valves inoperable until that first valve is released. This is the case with the accessory Case control valve that was intended for the VAC. Denending on your control valves, it might be possible to replumb the hydraulic system so that the loader has priority over the eagle hitch or vice/versa, and eliminate the valves. It is not a problem with pressure, it is just the way that the system works. |
01-30-2013 21:17:28
76.226.26.182
Re: Eagle hitch and loader valves on same hydraulics? in reply to Christopher Mikesell, 01-30-2013 21:13:12
| In other words, your system is working like it should. Also, we need to know exactly what you have for control valves in order to advise you on how to hook it up. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
