TractorLinks.com
Show Parts for Model:
Re: Hairline cracks in SC block
C. Amick
01-30-2013 16:04:41
Was there any antifreeze in the oil? If not, I doubt that you have a problem with these cracks. Can you put some coolant in the block and check for leaks below in case there are other cracks down lower on the block.
Zach from TX
01-30-2013 16:33:28
 Re: Hairline cracks in SC block in reply to C. Amick, 01-30-2013 16:04:41
No water in the oil that I could tell.
C. Amick
01-31-2013 15:34:46
 Re: Hairline cracks in SC block in reply to Zach from TX, 01-30-2013 16:33:28
The head gasket should seal around the lip of the sleeve to keep any coolant that leaks through the cracks up on top of the block from getting into the cylinders. I usually use copper spray on my head gaskets to get a good seal, but others will tell you not to.
dboll
01-31-2013 17:58:10
 Re: Hairline cracks in SC block in reply to C. Amick, 01-31-2013 15:34:46
True,but what's going to keep coolant from seeping into the push rod galley?
