case back hoe cant get it running
dhlickboy
New User
have a case 480f cant get running someone ran it out of fuel . now wont start. i am getting fuel to injector pump but it is not coming out of the lines that go to the injector! also some one replaced solenoid under the injector does this have to be set at a certain depth or something
im experiences with running out of fuel mostly have to bleed pump and prime pump try removing return hose and with cap on tank put air pressure to return line should prime the pump
there is a small "plug" in the fuel rail after the filter remove plug turn over untill fuel comes out, install plug and bingo running
