!938 Case w/ Waukesha 4-cylinder Engine
Wayne12
New User
Have a problem with the block. Had it magna fluxed and it has a crack. I would guess it's in the water jacket. Coudn't find any external cracks.
Anybody know of a place or someone who might have a block that would fit. I know David Brown was close to Case. Any help would be helpful.
Thanks.[/b]
Waukesha FC engngine , used a lot in forklifttrucks, Have seen these engines used in the air force for starting aircraft during WW2
David Brown has nothing to do with these engines .
my advice is that if you are using this tractor for an FFA project to find something more contemporary that would be easier to find parts for with a modern engine equipped with overhead valves so that your students can be taught skills like engine assembly, parts measurement and adjusting valves that can be used all the way to current engines if they chose to go into that kind of work
(quoted from post at 03:58:51 01/26/13) I have used Wauk. blocks.
Don L.
read your post. thanks. I see you live in Minnesota. I live in Washington (west coast). Let me know your terms. See what I can do.[/quote]
