451 sleeves in a504 block
Anonymous-0
Was wondering if sleeves from a 451 turbo engine would fit in a504 turbo block.Thinking of 466 class using 504 block.
What are you trying to achieve? I can't think of a reason to do that. It would be easier to move any 504 parts you want to the 451 block.
you could destroke the 504 a little if they will let you, then you can keep the heads with the big injectors and valves without having to cut into the sleeve to clear them
