Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Bad Bearing Right belt pulley shaft
[Return to Forum]
L.LAMP
01-27-2013 11:35:28
12.73.111.75
What is the easiest way to replace this bearing on an SC?
[Reply]   [No Email]
TexasCC
01-27-2013 17:17:59
72.47.34.25
Trust me--where there's one bad bearing, there are many. This bearing under the belt pully is on the bevel gear shaft. If done correctly, any bearing replacement must involve resetting the backlash adjustment on the bevel pinion set. You could remove the belt pulley and the bearing carrier, cut the cage off the bad bearing and use a 3-jaw posi-lock puller to remove the inner race, heat the new bearing cone to around 300F and slide it on. An I&T service manual will give you just enough information to get you through setting up the dimensions on the shaft. You will have to pull the top transmission cover to access the gear set to do the job correctly. I would advise checking everything else carefully while you are in there. Best of luck!
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
