Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case 1030 Hydraulic Control Unit
just thinkin
01-27-2013 05:21:24
Hope this is not the problem,but. Does the pto turn without anything hooked to it? If it does most likely the clutch needs adjusted. The hydraulic may have a stuck valve. If the pto does not turn when engaged with nothing hooked to it there is a possibility that the drive shaft from the engine is broken or not in the tractor. I have seen them put together after a drive clutch replacement and the drive gear left off of the flywheel. Make sure you have power to the back
doc bob
01-27-2013 18:08:17
 Re: Case 1030 Hydraulic Control Unit in reply to just thinkin, 01-27-2013 05:21:24
hey just thinkin thanks for the great advice the pto turns very slowly with no load have been able 2 get it 2 stop with a 2x4 underneath it keep the advice coming i need every bit of it
